TrineSYS
3 years agoCan't launch Questa Intel FPGA Simulation software...
make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. The env variable is set correctly. Path is set. H...
SyafieqS
3 years agoJust for sanity check, if you are using free license, specify it correctly, does Questa able to launch? Questa Starter Edition.
