TrineSYS
3 years agoCan't launch Questa Intel FPGA Simulation software...
make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. The env variable is set correctly. Path is set. H...
SyafieqS
3 years agoDid you have any Questa license? if you used paid one, you need license, if you use free one also need license which can be generated in sslc. Please verify that since the message is pointing to licensing
TrineSYS
3 years agoThis is just a snip of the initial part of the license file. For giggles I have both the Starter edition and the Questa Plus version licensed as shown in the product summary. The other features in the license file are populating within the application as found under 'License Setup'
Also, here is the end of the license file where the Questasim licensing has been included.
