TrineSYS
3 years agoCan't launch Questa Intel FPGA Simulation software...
make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. The env variable is set correctly. Path is set. H...
SyafieqS
3 years agoMake sure to check the license path in env variable.
To set it properly sometimes all this minor can cause hard time.
- TrineSYS3 years ago
Thanks for the reply on checking the license path environment variable. The path is set correctly (hasn't changed actually). Additionally, other portions of the licensing file is read and seen within the app when going into the 'License Setup' area. Only have an indication of licensing issue when trying to run simulation. Only thing changed from prior year was that we replaced ModelSim with QuestaSim due to ModelSim being EOL and no longer able to renew the University academic licensing.
