Can't launch ModelSim on Linux with Quartus 18.1 installation.
I faced the same problem how did u solved it.? pls share the steps
- GShim27 years ago
I don't remember exactly how I fixed it, but I have it documented somewhersomewhere. I'll come back and post it as soon as I can find it.
- GShim26 years ago
I'm sorry it took me so long to get back to you. You may have already found a solution, but I'll post it here anyway.
After installing the mentioned libraries, I also installed ncurses5-compat-libs from archlinux AUR. You can find equivalent libraries for other distros online.
After that, I edited the vco file in {INSTALLATION_PATH}/modelsim_ase/vco
first uncommented line reads:
mode=${MTI_VCO_MODE:-""}
which I changed to
mode=${MTI_VCO_MODE:-"32"}
also, I changed the lines where it was written:
vco="linux_rh60"
to
vco="linux"
finally, I added the line below to the beginning of the vco file:
export LD_LIBRARY_PATH={INSTALLATION_PATH}/lib32 where I had installed the previous libraries, as instructed by the archlinux wiki.
After that, I could run modelsim straight from the terminal.
To open model sim from GUI, I also had to add the same line above to the script qenv.sh located in {INSTALLATION_PATH}/quartus/adm/qenv.sh
this solved it for me.
I will update with a more detailed explanation at some point, but you might be able to fix your problem with that.
Guilherme Shimabuko
