raghavendra_keshmoni
5 years agoCan't generate programming files because you are currently using the Quartus II 13.1
I downloaded and installed Quartus II 13.1 free edition in my PC to program Cyclone III device. After compiling the VHDL code, the software couldn't able to generate Output files (.jic, .pof), the below warning message is displayed
Warning (292011): Can't generate programming files because you are currently using the Quartus II software in Evaluation Mode
Help me out with the solution to proceed further
1 Reply
- NurAiman_M_Intel
If you are using Quartus® II design software subscription edition in the 30-day free evalution mode then no programming file(s) will be generated. You will need a valid license file to enable programming file generation.
Aiman
