16 years ago
Can't fit 1032 registers in device
I'm trying to configure a 256x8 RAM on a MAX7000S EPM7128SLC84-7 and I'm getting this error : "Can't fit 1032 registers in device".
This is the part of the code that is getting me in troubles:
type ram256x4 is array (255 downto 0)of std_logic_vector(3 downto 0);
signal matriz: ram256x4;
If I change the dimensions of the array to a smaller one {(4 downto 0) of (3 downto 0) for instance} it compiles. However I need the 256 positions, and it seems to me that according to the 16 dip switches available on the UP2 Education Board there should not be any problem.
Does anyone have any idea on how should I proceed in order to solve this issue?
Thanks in advance,
siLf
    Your code is inferring a RAM that will be implemented internally to the MAX device. The MAX device does not contain any RAM so the memory will be constructed from Registers.
    The MAX 7128 device contains 128 Registers. The large RAM you are inferring will use 256x4 (1024) registers...which is way too many! The smaller one you tested with will use 5 x 4 (20) registers which easily fits.
    Did you intend for the RAM to be an external memory component, i.e not internal to the PLD?
    I do not quite understand the connection to the 16 DIP switches. Perhaps you could provide a few more details as to what it is you are trying to design.
    Rgds
    Thanks for your response.
    What I am trying to do is to develope a RAM using addressing, control and data buses:
    - 8 bit address bus
    - 4 bit data bus
    - CS, OE, WR, RM (Chip Select, Ouput Enable, Write Memory, Read Memory).
    I have been able to configure the 256x4 RAM on the FLEX10K70RC240. Does this mean that the FLEX device contains all the necessary registers to do so?
    Here is the code I am using:
    entity Memory is
    port(
    clk: in std_logic;
    CS: in std_logic;
    OE: in std_logic;
    WR: in std_logic;
    Addr1: in std_logic_vector(7 downto 0);
    Data1: inout std_logic_vector(3 downto 0)
    end Memory;
    architecture behav of Memory is
    begin
    process(CS, OE, clk)
    begin
    if (clk'event and clk='1') then
    if (CS='1')then
    case OE is
    when '1' =>
    Data1<= matriz(conv_integer(Addr1));
    when '0' =>
    Data1<= (Data1'range => 'Z');
    end case;
    end if;
    if (WR='1') then
    matriz(conv_integer(Addr1))<=Data1;
    end if;
    end if;
    end process;
    end behav;
    Regarding the 16dip switches that come along with the UP2 Education Board. I was intending to implement them as my input ports (Addr1, Data1, OE,....) (to the MAX) avoiding to use any external wires to my board.
    Thx,
    siLf
    The said FLEX10K device has 3.7k LE (=registers) and 18kbit internal RAM.
