12 years ago --- Quote Start --- A ripple clock is a clock that is generated via logic - ie. exactly what you have done - used a counter to create a slower clock from a faster one. It is better practice to use the same clock over the whole system and generate clock enables to only enable the target at the given rate. So to divide a clock by 50, you create an enable signal that is high for 1 clock cycle in 50:
process(clk)
begin
if rising_edge(clk) then
if en = '1' then --only high once every 50 clocks
--logic with 1/50 clock
end if;
end if;
end process;
Another question - have you created a testbench to test this code in the simulator before you go to the hardware (it will make your life easier) --- Quote End --- Okay, so enable is also declared as a signal? but how exactly do you "enable" the clock? Isn't it always running? I don't see any control signal to actually control the output do the clk? Clk is declared as an input port.
