Gyud0
4 years agoCan't erase/reprogram EPCQ Flash via Quartus Prime Programmer
Hey,
I was successfully reprogram and erase a .JIC file to EPCQ MT25QL512 Flash device via Quartus Prime Programmer. The Flash is connected to Cyclone V device.
After that, I accidently made a ....
YuanLi_S_Intel
4 years agoDid u change the starting address also if you set page0 address at other addresses. Also, are you using USB Blaster II? Can you try to reduce the TCK frequency?
Gyud0
4 years agoYeah, I reduced the TCK frequency to 6/1Mhz and I was programming the FPGA with a .sof file.
After that, I was trying again to program/erase the Flash with a valid .JIC file but it failed again with the same error and after 53% in the process
