Can't download Quartus software - links broken?
SyafieqS,
You don't seem to be reading everything. The original issue was the inability to download due to Java script issues with the website. I suspect these issue still exist. This was resolved by members in the Reddit community, not by anyone at Intel, as they described how to work around it.
After downloading the Lite version I could not install the USB Blaster drivers as they are expired. Note I only need the Lite version because I am not the FPGA designer and I just need to load the FPGA using the USB Blaster. Windows 10 does not let you install expired drivers and my IT department also won't allow that. Expired drivers are packaged with the Lite version. You then said I should go download the drivers from another location without actually checking to see if the drivers were actually there. The drivers for the USB Blaster are not there, just a document saying you need to install the Quartus package to get them. DO YOU SEE THE PROBLEM????????
You need to repackage the Lite version with new drivers. Why is this so hard to understand??????
The level of support after Intel took over Altera is very disappointing.
