MDARG
7 years agoCan't add IP to my project
Every time I try to add IP from the IP catalog to my project I just see the 'IP Parameter Editor' text popping up for 1sec but the editor doesn't appear. Tried it many times with different IPs. Anyb...
Vicky1
7 years agoHi,
It may happen due to global environment variable pointed to different version installed on machine.
Generally whenever quartus launches, it will override the 'QUARTUS_ROOTDIR' environment, but not the 'QUARTUS_ROOTDIR_OVERRIDE' one, which need to be manually changed if a different version of quartus is assigned.
Check the below solution too,
Vikas Jathar
MDARG
7 years agoThanks for the response,
after setting the 'QUARTUS_ROOTDIR_OVERRIDE' variable to the same as set in 'QUARTUS_ROOTDIR' I still have the same issue. '_JAVA_OPTIONS' variable was never set in my system.
Unfortunately this does not solve the problem. If it helps I got the same issue when opening the Platform Designer.
