9 years agoCannot see the HTML GUI reports
Hi, I have a nallatech PCIe FPGA board and I'm compiling and running OpenCL code on it. While browsing the "Best Practices" guide, I've realized after each compilation there should be a "report...
9 years agoHi all! I have the same problem of sbiookag, after compilation process don't see the report folder neither the report.html file. I'm using Quartus/AOC v17.0 with a valid license (although for compilation process the license is not needed). The exactly version when invoque aoc --version is:
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 17.0.0 Build 595 I've tried many things but... unafortunately can't never generated the report file. Have you been able to solve this? Could you help me? Thanks in advance!
