Cannot proceed because MSVCR120.dll was not found
- 5 years ago
Please check that the LM_LICENSE_FILE is directed to a license file. Modelsim Intel Edition required a license.
How to set LM_LICENSE_FILE:
In the command prompt:
setx LM_LICENSE_FILE <license file path>example: C:\intelFPGA_pro\21.1\license.dat
Richard Tan
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
sorry for the late reply, caught on some other work.
actually i didnt tried installing on other PC. but I tried to install the quartus prime lite version.
and while running the simulation library compiler it shows as follows
Info: Command: quartus_sh --simlib_comp -tool modelsim -language vhdl -tool_path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ -directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite -rtl_only
Info: Quartus(args): -tool modelsim -language vhdl -tool_path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ -directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite -rtl_only
Info: Changing the current directory to output directory C:/Users/murali.kumar/Desktop/OLD_SIM/learn/prime_lite ..
Info: Using Path C:/intelFPGA_lite/20.1/modelsim_ae/win32aloem/ that was set in EDA Simulation Library Compiler Options
Info: Generating commands to compile library altera ...
Info: Generating commands to compile library lpm ...
Info: Generating commands to compile library sgate ...
Info: Generating commands to compile library altera_mf ...
Info: Generating commands to compile library altera_lnsim ...
Info: Executing command file containing library compilation commands
Info: Unable to checkout a license. Vsim is closing.
Error: ** Error: Invalid license environment. Application closing.
Info: Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Info: Modelsim - Intel FPGA Edition uses the following environment variables to check the licenses (listed in the order of preference)
Info: 1. MGLS_LICENSE_FILE
Info: 2. LM_LICENSE_FILE.
Error: Compilation was NOT successful. 1 errors, 0 warnings
Kindly do the needful
MuralikumarM
- RichardT_altera5 years ago
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- MuralikumarM5 years ago
