cannot launch modelsim software from quartus tool
in-spite of providing the correct path of modelsim software, its not working
- NGoud
Thanks, its working now.
- AnandRaj_S_Intel
Hi @NGoud ,
Configure Quartus II to work with ModelSim-Altera in native link mode:
· On the Tools menu, click Options. The Options dialog box appears.
· In the General list, select EDA Tool Options.
· For ModelSim-Altera, type the path or browse to the directory containing ModelSim-Altera. The directory should be located under the Altera directory, e.g. C:\<Quartus installation directory>\\modelsim_ase\win32aloem
· Select OK.
Also try by stetting PATH environment variable PATH=C:\<Quartus installation directory>\modelsim_ase\win32aloem.
Which version and edition of quartus are you using?
Anand
- NGoud
I had provided the modelsim.exe path and when i wanted to run the simulation tool it's giving native link error: did not specify the path to the executables.
Niharika
- AnandRaj_S_Intel
Can you attache some image which show your settings?
Have you flowed above mentioned steps?
Please refer image for setting
Anand
- AnandRaj_S_Intel
- NGoud
I'm using quartus prime standard edition 17.0
In qsys -> IP Catalog , libraries section ->(generic component ->black box)
i couldn't find the generic component option
