Cannot Install USB Drivers
I cannot install the USB drivers that come with my Quartus installation. I have seen other users also with this issue: https://community.intel.com/t5/Intel-FPGA-Software-Installation/USB-blaster-won-t-install-certificate-outdated/td-p/1255595
It appears that the driver is not properly signed. I am attempting to use Quartus at my workplace where installing non-signed drivers is a violation of our information systems policy. I cannot disable this check to install the improperly designed drivers. Can this be fixed?
- YuanLi_S_Intel
May i know which quartus version you are using? For the latest version, it should be no problem at all.
For old version, the only solution is to unsigned the driver.
Thank You.
Bruce
- hwardlaw
This is with the latest version 20.4
- YuanLi_S_Intel
Seems like there is a need to reinstall the USB driver. Can you try by referring to the KDB below?
Bruce
- hwardlaw
Bruce,
That worked, thank you! I find it curious that Intel's user guide documentation does not mention this updated driver, nor has Quartus been updated to include it. However, I do appreciate your help.
