Cannot find JTAG cable. Aborting installation.
I am trying to setup FPGA installation in azure VM. My azure VM comes with intel Arria 10 card. when i tried to run FPGA_install.sh I am getting the following error.
root@azlwu2testvm01:/home/azureuser# source fpga_install.sh
Found a compatible OS.
Intel FPGA Download Cable Driver is installed.
| OpenVINO FPGA Environment Setup Script |
Using the QUARTUS_ROOTDIR value: /home/azureuser/intelFPGA/18.1/qprogrammer/bin/bin
Using INTELFPGAOCLSDKROOT value: /opt/altera/aocl-pro-rte/aclrte-linux64
INTELFPGAOCLSDKROOT is set to /opt/altera/aocl-pro-rte/aclrte-linux64. Using that.
aoc was not found, but aocl was found. Assuming only RTE is installed.
AOCL_BOARD_PACKAGE_ROOT is set to /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1. Using that.
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/bin to PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/linux64/lib to LD_LIBRARY_PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/host/linux64/lib to LD_LIBRARY_PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1/linux64/lib to LD_LIBRARY_PATH
[setupvars.sh] OpenVINO environment initialized
Creating initialization script /home/azureuser/init_openvino.sh ...
Installing the new OpenCL BSP for the 2020.1 BSP. Enter Y when prompted to install (Enter sudo credentials when prompted):
Cannot find board_env.xml in /opt/altera/aocl-pro-rte/aclrte-linux64/board/a10_1150_sg1
1 Reply
- AnilErinch_A_Intel
Hi ,
Please check the below link
https://www.intel.com/content/www/us/en/programmable/documentation/iga1446847781805.html
for JTAG related queries.
Especially section 3.1. Turn ON/OFF Auto-Adjust Feature
Please let us know the exact results of running jtagconfig and whether Auto-Adjust is enabled or not .
Thanks and Regards
Anil
