8 years agoCannot edit the generated PLL Intel FPGA IP v18.0
Hi All,
I am using Quartus Prime v18.0 and generated PLL IP v18.0. I have successfully generated the PLL and added into the project but when I tried to modify it in the IP components, the MegaWizard failed to launch, below is the complete message of the problem. "Failed to launch MegaWizard Plug-In Manager. PLL Intel FPGA IP v18.0 could not be found in the specified library paths." See attachment for the screenshot. I tried other IP components, like FIFO, ALTLVDS_RX, ALTLVDS_TX, ALTCLKCTRL, all of it works fine. Quartus Prime: Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition Target Device: Arria V GX (5AGXBB3D4F35I5) Machine: Windows 10 Pro 64bit Also, I tried the same thing on other PC (Windows 7) but the problem is the same. Need help to fix this issue. Thank You. Zeahr12 Replies
- MAmin
I got it. Was able to find the .lst file in the install directory.
For those who are also stuck.
C:\intelFPGA\18.1\ip\altera\alt_xcvr\altera_xcvr_native_phy\cv
