8 years agoCannot edit the generated PLL Intel FPGA IP v18.0
Hi All, I am using Quartus Prime v18.0 and generated PLL IP v18.0. I have successfully generated the PLL and added into the project but when I tried to modify it in the IP components, the Me...
8 years agoThank you schendel.
Changing the alias name of the IP in the .lst file does fix the issue. Thanks for the solution. I started with "root_wizard.lst" and followed a few of the other paths to the individual IP's .lst files. It looks like Intel has not had anybody go through and scrub the all <IP name>.lst files, yet. Sure would have been easier to just leave everything "Altera" and call PSG something like Intel's Altera Group or just Intel/Altera.
