12 years agoHello, Daixiwen!
Every time I get the .elf file I implement "Run As->Nios II Hardware". The application is loaded into FPGA and runs. Leds flash displaying the working counter, the Nios II - Eclipse CDT Build Console displays the numbers from counter outputs. Then I stop the process and then repeat creating the application (I delete the project and BSP from the software folder) Then I create memory initialization files, add meminit.qip to the hardware project, recompile it and configure the FPGA. But the application does not work. The bsp in my software project is created by the Nios II - Eclipse with the application project cimultaneously. Regards, tduty
