12 years agoThank you, Daixiwen!
Unfortunately my CPU does not start after configuration. May be the reason is that I use the Altera Nios II Hardware Device Tutorial example for I don't know what tricks the Altera inserts to limit user's possibility in project modifying. Obviously my new .sof is not able to work. I believe every application section contains in the internal memory. But I don't know how to check it. To verify everything was done correctly I created this project once more. The result is the same. What is wrong? Regards, tduty
