8 years ago
Cannot access $ieee in modelsim.ini
We are certain that we had good Quartus and modelsim installation, and inside modelsim.in:
[Library]
std = $MODEL_TECH/../std
ieee = $MODEL_TECH/../ieee
verilog = $MODEL_TECH/../verilog
vital2000 = $MODEL_TECH/../vital2000
std_developerskit = $MODEL_TECH/../std_developerskit
synopsys = $MODEL_TECH/../synopsys
modelsim_lib = $MODEL_TECH/../modelsim_lib
sv_std = $MODEL_TECH/../sv_std
although the above variables are defined, they cannot be printed with "set"
set ieee# can't read "ieee": no such variable
only the following variables, which are listed in to "ModelSim® User's Manual, v10.5b", are accessible, but many are not defined in modelsim.ini
Simulator Control Variables
As with GUI Mode and Command Line Mode, simulator control for Batch Mode simulation is governed by which modelsim.ini variables are enabled and each variable’s setting.
AccessObjDebug IgnoreSVAError StdArithNoWarnings
BreakOnAssertion IgnoreSVAFatal UserTimeUnit
CheckpointCompressMode IgnoreSVAInfo PrintSimStats
ClassDebug IgnoreSVAWarning WildcardFilter
DefaultForceKind IgnoreWarning WLFCompress
DefaultRadix IterationLimit WLFFilename
DelayFileOpen NoQuitOnFinish WLFMCL
ForceSigNextIter NumericStdNoWarnings WLFOptimize
GCThreshold OnBreakDefaultAction WLFSizeLimit
Is this behaviro (not all modelsim.in variables accessible, whereas other variables not defined within modelsim.ini are accessible) by design?
greg
    Have you used
    SYNTAX:set ieee= directory?
    Can you attach the transcript?
    Anand Raj Shankar
    The correct Tcl grammar would be "set ieee directory", without assignment symbol. The line inside the default installation generated modelsim.ini is "std = $MODEL_TECH/../std". Here is the full .ini:
    ; Copyright 1991-2009 Mentor Graphics Corporation
    ; All Rights Reserved.
    ; THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION WHICH IS THE PROPERTY OF
    ; MENTOR GRAPHICS CORPORATION OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
    ; Altera Primitive libraries
    ; VHDL Section
    altera_mf = $MODEL_TECH/../altera/vhdl/altera_mf
    altera = $MODEL_TECH/../altera/vhdl/altera
    altera_lnsim = $MODEL_TECH/../altera/vhdl/altera_lnsim
    lpm = $MODEL_TECH/../altera/vhdl/220model
    220model = $MODEL_TECH/../altera/vhdl/220model
    maxii = $MODEL_TECH/../altera/vhdl/maxii
    maxv = $MODEL_TECH/../altera/vhdl/maxv
    fiftyfivenm = $MODEL_TECH/../altera/vhdl/fiftyfivenm
    sgate = $MODEL_TECH/../altera/vhdl/sgate
    arriaii = $MODEL_TECH/../altera/vhdl/arriaii
    arriaii_hssi = $MODEL_TECH/../altera/vhdl/arriaii_hssi
    arriaii_pcie_hip = $MODEL_TECH/../altera/vhdl/arriaii_pcie_hip
    arriaiigz = $MODEL_TECH/../altera/vhdl/arriaiigz
    arriaiigz_hssi = $MODEL_TECH/../altera/vhdl/arriaiigz_hssi
    arriaiigz_pcie_hip = $MODEL_TECH/../altera/vhdl/arriaiigz_pcie_hip
    stratixiv = $MODEL_TECH/../altera/vhdl/stratixiv
    stratixiv_hssi = $MODEL_TECH/../altera/vhdl/stratixiv_hssi
    stratixiv_pcie_hip = $MODEL_TECH/../altera/vhdl/stratixiv_pcie_hip
    cycloneiv = $MODEL_TECH/../altera/vhdl/cycloneiv
    cycloneiv_hssi = $MODEL_TECH/../altera/vhdl/cycloneiv_hssi
    cycloneiv_pcie_hip = $MODEL_TECH/../altera/vhdl/cycloneiv_pcie_hip
    cycloneive = $MODEL_TECH/../altera/vhdl/cycloneive
    stratixv = $MODEL_TECH/../altera/vhdl/stratixv
    uploaded file:http://s000.tinyupload.com/index.php?file_id=30816614244553470924
    After launching modelsim, what is weird is that
    but we can assign and read back:
    set ieee "C:/intelFPGA_lite/16.1/modelsim_ase/std"# C:/intelFPGA_lite/16.1/modelsim_ase/std
    set ieee# C:/intelFPGA_lite/16.1/modelsim_ase/std
    So it seems that the line for ieee in modelsim.ini was ignored. Should that be?
    greg
    Yes, you are correct we are not able to read directly by using set IEEE.
    But we can see simulation libraries are loaded/read automatically by vsim with help of environment variable( MODEL_TECH).
    example:
    # vsim -c top
    #  Loading .../modeltech/sunos5/../std.standard
    #  Loading work.top(a)
    #  Loading work.for_model(a)
    #  Loading ./for_model.sl
    #   myentry = $MODEL_TECH/xyz
    #   myentry = .../modeltech/sunos5/xyz
    #   std =  $MODEL_TECH/../std
    Anand Raj Shankar
