15 years agohello.
supalshah75's answer is kind of right answer. I think wh2010 wants to know more about this. I say that. you can not write in C language directly. but you have another way. such as, you can put a CPU ( NiosII ) and run your program on the CPU which is running on the FPGA. or you can try SystemC. I can not describe SystemC much. but it is kind of C language for FPGA. did I help you?
