CSoti
7 years agoCan we define custom libraries for custom IPs in Platform Designer?
When I add a custom IP under platform designer I also add the source files for the accompanying custom libraries, but it is not clear if in synthesis the libraries are compiled under the library nam...
CSoti
7 years agoThank you, I have already done that but it didn't seem to generate a library to refer to in Quartus. When I exported the project to be simulated in Modelsim I had to add the library by hand in both quartus and modelsim in order to be able to compile and simulate. Can I define a library with a specific name in a specific folder as I add the list of files as I add them for the custom IP? From the GUI this doesn't seem to be the case but if I could do it through a script it should also work.
