8 years agocan single work items kernels run in parallel on same device
Can single work item kernels run in parallel on the same device (i.e. on the same board). I've been trying to get a very simple example of task parallelism working but have not been able to ...
8 years ago --- Quote Start --- What about: I - Add a clFlush after each clEnqueueTask() II - Profile the FPGA design (or print all start and end timestamps of the kernels' events) to see if kernels overlap in time. --- Quote End --- I - I thought this was a "no-no" for parallel operations. I'll try it. II - I did "compile" with the profile on the original code (the above it a watered down version of the real objective) and it pretty clearly showed no over lapping.
