8 years agocan single work items kernels run in parallel on same device
Can single work item kernels run in parallel on the same device (i.e. on the same board). I've been trying to get a very simple example of task parallelism working but have not been able to ...
8 years ago --- Quote Start --- And what about moving the "start_time = getCurrentTimestamp()" call? --- Quote End --- Same result.... code update snippet....
const double start_time = getCurrentTimestamp();
// Launch the kernels
for ( int kz=0; kz<kerns; kz++) {
status = clEnqueueTask(queue, kernel, 0, NULL, &task_event);
exitOnFail(status, "Failed to launch kernel");
results with 8 kernels.... $ bin/host 100000000 8 get_plat_info: Intel(R) FPGA SDK for OpenCL(TM) Reprogramming device [0] with handle 1 Task:0 complete (3437.884 ms) Task:1 complete (6875.553 ms) Task:2 complete (10313.318 ms) Task:3 complete (13751.042 ms) Task:4 complete (17188.784 ms) Task:5 complete (20626.527 ms) Task:6 complete (24064.256 ms) Task:7 complete (27501.988 ms) Time: 27501.995 ms (3437.749 ms / kernel) Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 and results with 4 kernels.... $ bin/host 100000000 4 Reprogramming device [0] with handle 1 Task:0 complete (3437.864 ms) Task:1 complete (6875.626 ms) Task:2 complete (10313.367 ms) Task:3 complete (13751.130 ms) Time: 13751.135 ms (3437.784 ms / kernel) Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 Sum 0-100000000.000000 (step 1.000000) = 5000000050000000.000000 I have four boards. In other code, I can launch different numbers of kernels of each of the four boards. When I do this, I do see the speed up I'm looking for. e.g. If I run 1 kernel on each of four boards, it takes time X ms. But, When I run 4 kernels on one board, it takes approx. 4 * X ms (as shown above).
