Can not reply the topic "Instantiation of DDR3 SDRAM Controller with UniPHY intel FPGA IP"
Hi Adzim,
FYI:
The NIOS timing violation are as follows:
Slack from note To Node
-6.263 NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|d_address_tag_field[12] NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|A_dc_wb_rd_addr_offset[0]
-6.263 NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|d_address_tag_field[12] NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|A_dc_wb_rd_addr_offset[0]~DUPLICATE
-6.262 NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|d_address_tag_field[12] NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|A_dc_wb_rd_addr_offset[1]
-6.183 NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|d_address_tag_field[12] NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|A_dc_wb_rd_addr_offset[0]
-6.183 NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|d_address_tag_field[12] NIOS:nios_u|NIOS_nios:nios|NIOS_nios_cpu:cpu|A_dc_wb_rd_addr_offset[0]~DUPLICATE
please refer to the attached file for detailed information.
However, even with these timing violation, all functions implemented with NIOS can work well.
Scott
