PapaPerc
4 years agoCan I use virtual pins with SignalTap?
Hello all. I’m implementing a simple 5x5 8bit matrix multiplier using VHDL. I’m using DE10-lite as my FPGA and since it doesn’t have enough pins to support 3 200 bit busses, I used virtual pin assign...
hareesh
4 years agoHi PapaPerc,
Through the signal tap doesn't possible to assert that input data. go through the bellow video you will get virtual pins selecting and monitoring the signals.
link:
- sstrell4 years ago
Virtual pins don't let you assert signal values as OP is asking about. They're just placeholders for I/O.
