PapaPerc
4 years agoCan I use virtual pins with SignalTap?
Hello all. I’m implementing a simple 5x5 8bit matrix multiplier using VHDL. I’m using DE10-lite as my FPGA and since it doesn’t have enough pins to support 3 200 bit busses, I used virtual pin assign...
sstrell
4 years agoSignal Tap does not assert anything. It is for monitoring only. If you want to assert signal levels during runtime (like having switches to control internal signals), use In-System Sources & Probes.
