8 years agoCan I safely ignore these hierarchy connectivity warnings?
Hello, I have the following problem that I have not been able to solve by searching the Forums: I have a system with a Nios2 gen2 processor and the nios_custom_instr_floating_point custom instr...
8 years agoYou can safely ignore them if you know those ports are not needed in your design, along with the logic that drives them.
Otherwise you will need to investigate why they are not connected
