Can I program Cyclone V devices without having a license? We have the programming file .sof. we don't want to compile.
- sstrell
You can also download just the Programmer if you don't want to download and install the full Quartus software:
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
Click "Select by Software" and then choose "Programming Software."
#iwork4intel
- AnandRaj_S_Intel
Hi @MGhad3 ,
Yes, you can program .sof file without any license.
Open Quartus with 30- days trial mode or without compilation mode go to Tools-> programmer ->auto detect ->select device->right click and change the file ->click on start.
Intel altera recommended to use programmer from same Quartus version & edition used to generate .sof file.
Anand
- AnandRaj_S_Intel
Hi @MGhad3 ,
Yes, you can program SOF files containing NIOS processor.
1.If you have time-limited sof file,We have to keep the USB blaster plugged in.
2.Or If sof file is generated using licensed quartus tool it's not necessary.
Anand
- AnandRaj_S_Intel
Yes, but it will be time-limited sof file for Quartus pro & Quartus std.
We can use Quartus Lite to generate sof(not a time limited) only if, we are not using any IP's which required license.
For example: If we use Quartus Lite to design a system with Nios II/f(which requires license) in 30-days train mode of quartus. Tool will generate a time limited sof file.
Anand
