8 years agoCalling EnqueuTask multiple times is not working.
I am running one program on my server with 32GB RAM. We have requirement to do matrix multiplication of 64x64x256 image with filter of the same size (64x64x256). Problem is that we have 2614600 such ...
8 years ago --- Quote Start --- The code looks like it should work. I'm wondering if the FC_weight_buf[0] isn't getting released somehow. Could you try moving the the clCreateBuffer and clReleaseMemObject outside the for loop and see if you get the same error? Doing an clEnqueueWriteBuffer should still work as expected but it'll just overwrite the data from the previous loop which isn't being used anymore. --- Quote End --- We already tried this. We are getting the same error. We are trying to run the attached program and kernel and we now getting the following output. If this code works then it can directly be used in our real application. This standalone code always terminates at 32732 iteration and Virtual memory in top command continuously increasing and after reaching at ~320GB, program gets the following error. --- Quote Start --- ...... Kernal 32729 -> 1.374 ms Kernal 32730 -> 1.309 ms Kernal 32731 -> 1.275 ms Context callback: Emulator: Could not start the kernel compute units. Kernal 32732 -> 1.152 ms host: acl_offline_hal.c:476: acl_emulator_hal_launch_kernel: Assertion `*thread == 0' failed. Aborted (core dumped) --- Quote End ---
