8 years agoCall to set_clock_groups fails for Stratix 10 Build
When my SDC file is read while compiling for a Stratix 10 device, the set_clock_groups command is failing. The failure occurs because at the point in time that the SDC file is read, the tool does no...
8 years ago --- Quote Start --- As I mentioned the IP should be constraining the clocks and I recommend getting that to work rather than trying to do it on your own. --- Quote End --- I was responding to the other post. I had to re-run because I regenerated one of my IP. I re-arranged the files, so I'm trying what you suggested. I should know shortly if changing the order helped with this issue. Thanks,
