8 years agoCall to set_clock_groups fails for Stratix 10 Build
When my SDC file is read while compiling for a Stratix 10 device, the set_clock_groups command is failing. The failure occurs because at the point in time that the SDC file is read, the tool does no...
8 years agoAs I mentioned the IP should be constraining the clocks and I recommend getting that to work rather than trying to do it on your own.
