8 years agoCall to set_clock_groups fails for Stratix 10 Build
When my SDC file is read while compiling for a Stratix 10 device, the set_clock_groups command is failing. The failure occurs because at the point in time that the SDC file is read, the tool does no...
8 years agoS10 clocks are constrained with the IP, so when you create a PLL or transceiver IP, it usually has an accompanying .sdc with it that constrains the clocks. You just want to make sure your .sdc is read in after this. If you go to Assignments -> Settings -> TimeQuest, push your .sdc to the bottom(or do it in Assignments -> Settings -> Files). After doing this, close TQ and re-open it(so it sees the changes) and see if that fixes it, before running a full compile.
