11 years agoCalculating parameter value with self-written function
I'm currently working on a project where I need to calculate the length of a specific vector with the help of a (constant) function. I use QuartusII (13sp1) and Systemverilog. The module parameters/ports look like this:module LZD# (
parameter INPUT_WIDTH = 54,
parameter OUTPUT_WIDTH = 6
input logic input_string,
output logic count
); Inside this module I have two localparams: localparam INTERN_WIDTH = 2**OUTPUT_WIDTH;
localparam POS_WIDTH = get_array_length; Where get_array_length is a function, that returns a value based on some calculation only with the other parameters. function int get_array_length(int OUT = OUTPUT_WIDTH, int N = INTERN_WIDTH);
int result = 0,k;
for (k=0; k<OUT; k++) begin : LOOP
result = result + (OUT-k)*N/(2**(OUT-k));
end
return result;
endfunction From what I have read about parameters, they can be assigned using functions if these are constant at compile time. Which my function should be, as it only uses parameters as inputs. When I compile this module on its own, I don't get any errors and synthesis also looks as intended. But this module is just a submodule. When I try to compile the top-module, I always get the following error: Error (10192): Verilog HDL Defparam Statement error at LZD.sv(24): value for parameter "POS_WIDTH" must be constant expression (Line 24 is "localparam POS_WIDTH = get_array_length"; ) In the top-module, LZD is instantiated via LZD# (
.INPUT_WIDTH(2*MANTISSA_WIDTH+1),
.OUTPUT_WIDTH(COUNT_WIDTH+1)
) LZD_Instance(
.input_string(mantissa_negate),
.count(leading_zero_count),
.no_one(no_one)
); and MANTISSA_WIDTH and COUNT_WIDTH are parameters inside the top-module. parameter MANTISSA_WIDTH = 27;
parameter COUNT_WIDTH = 5; Is this a bug, is QuartusII not able to get the parameter values out of the hierarchy or is there anything else wrong in my code? I tried to find anything related to such things, but all I could find were papers or posts that mention that it's possible to calculate a parameter with a constant function. (Which seems to work in case the module is not further instantiated) Thanks for any help!No RepliesBe the first to reply
