pnp
5 years agoBus index reversal when SystemVerilog module instantiates a BDF in Quartus Prime Pro 21.2
I have a legacy BDF that I need to use in a current design. Using Quartus Prime Pro v20.4 or v21.2, I see the bus indexes reversed on the port connections when the BDF diagram is instantiated from wi...
- 5 years ago
Yeah, I'd just convert to HDL and use that if you have more complex designs causing this issue. Just save yourself the time and effort trying to fix the schematics.
sstrell
5 years agoWeird. Have you tried explicitly specifying [3:0] in the instantiation or creating a wire to perform the concatenation outside of the instantiation?
- pnp5 years ago
Thanks! Yes, I tried all of those combinations that you suggested. Using a wire and concatenating results in the same reversed connections:
module top ( input logic clk, input logic [3:0] x, output logic [7:0] y ); wire [7:0] x_in; assign x_in = {x, 4'b0}; bdftest bdf_i ( .clk(clk), .x_in(x_in), .y_out(y) ); endmoduleAs does using a register:
module top ( input logic clk, input logic [3:0] x, output logic [7:0] y ); logic [7:0] x_in; always @(posedge clk) x_in <= {x, 4'b0}; bdftest bdf_i ( .clk(clk), .x_in(x_in), .y_out(y) ); endmoduleAs well as a register with explicit indexes in the assignment and instantiation:
module top ( input logic clk, input logic [3:0] x, output logic [7:0] y ); logic [7:0] x_in; always @(posedge clk) begin x_in[7:4] <= x; x_in[3:0] <= 4'b0; end bdftest bdf_i ( .clk(clk), .x_in(x_in[7:0]), .y_out(y) ); endmoduleAnd finally, same results with a wire and explicit assignment/instantiation:
module top ( input logic clk, input logic [3:0] x, output logic [7:0] y ); wire [7:0] x_in; assign x_in[7:4] = x; assign x_in[3:0] = 4'b0; bdftest bdf_i ( .clk(clk), .x_in(x_in[7:0]), .y_out(y) ); endmodule
