15 years agoBus concatenation
Hello all,
I have a 28 bit local bus. I have a RAM with 7 bit address input 6..0. I need to use the schematic editor to make the RAM address input be connected to bits Local_Bus[6..2] and ground the lower two bits of the RAM address input. To do this I need to concatenate bits from Local_Bus and this Ground bus, which is so very simple in VHDL but after much trying I cannot figure it out in the schematic editor. Here's a graphic to illustrate the situation. It's sort of a "fill in the blanks." Any ideas are greatly appreciated, thanks! :confused:
