9 years agoBuilding Quartus16.1 files on Quartus 16.0
Hi, So, I m working on top of a third party HDL framework, which is written specifically to be build on Quartus 16.1. It uses some of quartus IPs, (AlteraNative PHY just to name one, g...
9 years ago --- Quote Start --- That is to be expected - changing the seed affects the build, but also note that changing the source code in any way, or changing the project settings, also changes the build, so a good seed will not be good for all builds and versions. --- Quote End --- Tricky is right. with different compilation configuration, the placement, routing and internal resource utilization would change. This is why you would see different timing results with these different builds. Best Regards, bfkstimchan (This message was posted on behalf of Intel Corporation)
