8 years agoBuilding hello_world issue with embedded_command_shell
Hi, I have tried building hello_world host as well as other examples from de10_nano BSP. However, none of them were built successfully. They all met the same question: $ make arm-linux-gn...
8 years agoYou seem to have some Chinese characters in your path variables. It is likely that the compiler cannot parse such characters correctly. Apart from that, you seem to be using Cygwin on Windows. I am not sure if that is a supported method for compiling kernels against Intel FPGA SDK for OpenCL.
