8 years agoBuilding hello_world issue with embedded_command_shell
Hi, I have tried building hello_world host as well as other examples from de10_nano BSP. However, none of them were built successfully. They all met the same question: $ make arm-linux-gn...
8 years ago --- Quote Start --- Your environment does not seem to be set correctly. Follow Terasic's guides to set up your environment. --- Quote End --- Thanks for your answer. The environment I followed is the document named DE10-Nano OpenCL User Manual.pdf which I downloaded from the official website. I have set the environment AOCL_BOARD_PACKAGE_ROOT, LM_LICENSE_FILE, INTELFPGAOCLSDKROOT. As well as the two directories have been added into the PATH. I can compile all the kernels to generate aocx file but I have never get the host files compiled. Is there anything wrong? Looking forward to your reply.
