Altera_ForumHonored Contributor17 years agoBugreport : Programmer window is stuck [Quartus2 Version 9.0 Build 132 on WinXP SP2] The project is compiled, the programmer window is started, no programmer assigned, I click the hardware setup button and quartus freezes. I have to kill ...Show More
Altera_ForumHonored Contributor17 years agoBy the way, the OS devicemanager recognizes the USB Blaster and tags it as operational. Rene
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
