Bug! Quartus Pro 20.1.1, Cyclone V, utilizing PCIe example from 16.1.
- 5 years ago
I got it working.
The last hurdle was the MSI interface. I'm not sure why it wasn't working, but restarting the design from scratch with my recently acquired knowledge got everything working.
I've attached my qsys file and socfpga.dtsi. Hopefully it will help others get a jump on things so they don't have to learn everything the hard way as I did.
This design is not optimized for speed, nor is it optimized for space.
NVMe read speed is around 80 MB/s.
NVMe write speed is around 50 MB/s.
Faster drives will do a little better, but even the over a gig per second on PC 4 lane part I have doesn't do much better than 110 MB/s read. Bandwidth is limited by the ARM memory interface and the fact that bursting logic at 125MHz causes timing violations. A burst length of one on the Txs interface has got to slow things down.
Performance is quoted with the 5.11 kernel, the 5.4 kernel is not quite as fast. Still fast enough for an embedded system though.
Don't forget to enable the fpga, pcie and msi modules in your top level board dts file.
And don't forget to reserve the first 64K of DRAM as stated above. If you don't you will get read errors.
There are probably better configurations, and eventually I'll probably try to optimize for size since my logic will need to get bigger on the next project. But for now. It finally works.
Good luck to you all.
I download the CV simple design from the link below, open it at v20.1.1 standard version, change the device to 5CSXFC5D6F31C7, and then re-generate the Platform design. By doing so, it is able to compile successfully, and the logic utilization is 23%.
https://rocketboards.org/foswiki/Projects/PCIeRootPortWithMSI
Regards -SK
Thanks for the reply.
I ended up using this: https://releases.rocketboards.org/release/2015.10/pcie-ed/hw/cv_soc_rp_simple_design.tar.gz
I think that is the same one that you used.
When I included my design with it, it did not fit. I ended up reducing the PCIe modules functionality by reducing synchroniser memory usage and switching all my FIFOs to using M10K to save MLAB space.
The error I posted above occurred when I changed all the resync buffers to 1 deep, switched all my fifos to M10K and cut the 256K DMA buffer to 128K.
After I made the post, I cut the DMA buffer down to 60K and for the first time all the code fit and met timing.
Now that the FPGA seems like it might work, I need to get linux working with the PCIe port.
sopc2dts.JAVA does not generate a usable file. There are a few features I had to add to the source code to get it to run on the sopc file generated by 20.1.1 (the java did not know about altera_pll, and there was an issue getting the Txs port address due to a bug) . Even after those modifications and even though the kernel accepts it, it does not work and does not generate any error messages from the kernel. I end up with hardware that is missing a CPU, an ethernet and many of the other features, including PCIe.
If I could see a working example of the device tree for the pcie, msgdma, etc, then I'm certain I can get my hardware to work with the linux kernel using a manually created dts I made based on the socfpga device tree files found in the linux kernel.
Do you have an example of the device tree entries for this design that function on kernel 5.4 that you can show me?
Thanks again for your help. I really appreciate it.
