BSOD when using programmer
Let us tell you how to fix: PFN list corrupt BSOD on windows in several easy methods. The blue screen error usually occurs when you have a corrupt driver. Some of the windows 7 and 10 users said they had shut down the computer after having the bluescreen error.
However, the cause of the blue screen will vary from one computer to another. You will have the most convenient way to fix the fatal errors from our guide . The PFN error is the page frame number error related to the hard drive or physical disk.
According to our research, the cause of PFN list error can occur due to PFN corruption. You have to check the descriptor list and check the device drivers as well.
In most cases, the BSoD is occurring because you are using third-party applications or corrupt drivers.
Causes
The causes of PFN error could be the following:
- Issues in the RAM
- Corrupt hard drive
- Malware or any other virus issue
- Windows registry could be corrupt
- Damaged or corrupt system
- Outdated files or configuration of the device are not right.
