8 years agoBooth multiplier
Hey everyone, I have troubles with coding this Can somebody help me or did somebody this yet? Create and test the booth multiplier algorithm. The parameter should be the number of input opera...
8 years ago --- Quote Start --- It doesn't work , don't know the problem so it for I asked if somebody did it ;) --- Quote End --- So how does it 'not work'? Can you provide test case(s) showing inputs, received output, expected output? Do you have a test bench setup?
