8 years agoBooth multiplier
Hey everyone, I have troubles with coding this Can somebody help me or did somebody this yet? Create and test the booth multiplier algorithm. The parameter should be the number of input opera...
8 years ago --- Quote Start --- What problems are you having? why not let us help you rather than expecting other people do your work for you? --- Quote End --- Don't worry really don't know how to continue with that
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity RECODER is
port (
DIN : in std_logic_vector(15 downto 0);
BIT3 : in std_logic_vector( 2 downto 0);
DOUT : out std_logic_vector(16 downto 0));
end RECODER;
architecture RTL of RECODER is
constant N : integer := 16;
subtype bitn1 is std_logic_vector(N downto 0);
function COMP2 (D : in bitn1) return bitn1 is
variable Dn : bitn1;
begin Dn := not D;
return(Dn+1);
end COMP2;
begin
process (DIN, BIT3)
begin
case BIT3 is
when "001" | "010" =>
DOUT <= DIN(N-1) & DIN;
when "101" | "110" =>
DOUT <= COMP2(DIN(N-1) & DIN);
when "100" =>
DOUT <= COMP2(DIN & '0');
when "011" =>
DOUT <= DIN & '0';
when others =>
DOUT <= (DOUT'range => '0');
end case;
end process;
end RTL;
