9 years agoBoard 'de1soc' not found.
Hello for anyone, my friends, What's this, i don't understand.
9 years agoThat file should be in the same folder as the log that you posted earlier. In fact, you could zip (or better yet, 7-zip) the whole folder that is generated by the OpenCL compilation and attach that (skip any file inside it that is bigger than 20 MB). Also just to make sure, did you update to 16.1.0 or 16.1.1? The former does not work at all with OpenCL and you have to use 16.1.1. Please post the output of "aoc --version" command to make sure the OpenCL compiler has been updated correctly.
