11 years agoBlock Editor - changing the page or sheet size
Now that I have the Block Editor running (thank you), how do I change the default sheet size to something smaller, like B (11 x 17)? The default size is huge, making scaled-down B-size prints too small to read.
Thanks. ak1 Reply
Hie analogkid,
you can to File > Page Setup and select your page size then go to View > Show Page Breaks and you will see a blue border which shows you the edge of your sheet. you can verify this using the Print Preview =) hope this helps and good luck!
