Blank window when running Quartus Prime Lite in sudo mode Ubuntu 18
- 7 years ago
as mention, from my side, I just dont use the su. I also face stuck issue when try to edit the megawizard. It was resolve by https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/why-does-the-megawizard-got-hang-.html
Previously you typed that you was able to see the same thing. How did you resolve it?
- KennyT_altera7 years ago
Make sure the below to avoid the IP stuck.
1.Install Java from Oracle. Java version after install is:
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
2. Try to install Quartus in a directory path that has no uppercase letters.
3. Right after Megawizard is opened, stretch the window out a little (drag a corner) and make it so scrolling is not necessary.
4. make sure when you launch quartus, there are no error message showing lib is missing.
