MAlek2
7 years agoBlank window when running Quartus Prime Lite in sudo mode Ubuntu 18
Hello. When i'm running Quartus Prime Lite in sudo mode i see nothing but blank screen. I'm running Quartus with sudo because without it Quartus stucks when generates any IP. I tried 17.1 and ...
- 7 years ago
as mention, from my side, I just dont use the su. I also face stuck issue when try to edit the megawizard. It was resolve by https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/why-does-the-megawizard-got-hang-.html
KennyT_altera
7 years agoTry not using sudo. The IP generation success on my side. check again your lib https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2019/why-does-my-quartus-prime-18-1-fail-to-run-on-ubuntu-18-04-lts-.html?wapkw=why+does+my+quartus+prime+18.1+fail+to+run+on+ubuntu+18.04+lts%3f
MAlek2
7 years agoThis doesn't work for me, unfortunately. My Quartus stucks at any try to edit or create PLL, FIFO, etc. Running without sudo is not an option.
