MAlek2
7 years agoBlank window when running Quartus Prime Lite in sudo mode Ubuntu 18
Hello. When i'm running Quartus Prime Lite in sudo mode i see nothing but blank screen. I'm running Quartus with sudo because without it Quartus stucks when generates any IP. I tried 17.1 and ...
- 7 years ago
as mention, from my side, I just dont use the su. I also face stuck issue when try to edit the megawizard. It was resolve by https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/why-does-the-megawizard-got-hang-.html
KennyT_altera
7 years agoCan u check on your environment variable before and after su command? Perhaps after the su command, there are some environment change. I will check on my side as well. I will check again whenever the IP instances created , it got stuck or not.
