MAlek2
7 years agoBlank window when running Quartus Prime Lite in sudo mode Ubuntu 18
Hello. When i'm running Quartus Prime Lite in sudo mode i see nothing but blank screen. I'm running Quartus with sudo because without it Quartus stucks when generates any IP. I tried 17.1 and ...
- 7 years ago
as mention, from my side, I just dont use the su. I also face stuck issue when try to edit the megawizard. It was resolve by https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/why-does-the-megawizard-got-hang-.html
KennyT_altera
7 years agoYes.. seems like I was able to see the same.. will get back to you on this.. also, can you just use it normally?
MAlek2
7 years agoYes. I can run it normally but it stuck when generates IP instances
